Univariate state space model + exogenous variables
May-June
Unread post by May-June »
I'm trying to estimate a univariate state space model including one exogenous variable in the state and one exogenous variable in the observation equation.
I got problem at the DLM estimation with the error : ## MAT2. Matrices with Dimensions 1 x 5 and 3 x 1 Involved in ~~ Operation
So, please help me to see and fix the problem.
I attached here two files:
+ The first present the Unobservable component models
+ The second show the codes Rats
And please give me some advises to deal with this model.
Many thanks
state space 5jan2014.docx
The Unobservable Component Model
(12.31 KiB) Downloaded 867 times
TEST.RPF
The codes in Rats
(2.92 KiB) Downloaded 1117 times
Re: Univariate state space model + exogenous variables
The "C" matrix is entered into the model as a transpose, so CS is 3x1. You're combining that with a 1x5 CTC. BTW, CTC is a fixed matrix, so there is no reason for it to be a FRML---the only part of C that is time varying is PETROL. Either use TR(CTC) or redefine CTC as a 5x1 rather than 1x5 matrix.
May-June
Thank you very much. It works.
