Stacked Graph doesn't fill
wjc333
Unread post by wjc333 »
I am graphing variance decomps from a VAR using the stacked graph style but the data in the graph do not start filling in until observation 15 or so. My code and data are attached. Any help would be appreciated.
VDC_CAN.zip
Program with data file
(70.06 KiB) Downloaded 714 times
Re: Stacked Graph doesn't fill
Move the
smpl 1 nstep
up before the ERRORS instruction. The SET instructions for VDC11, etc. as you've written in will be governed by the "smpl ibegk iend"
wjc333
Thanks Tom that did the trick.
