2-pass regression with time series data
fan
Unread post by fan »
I am trying to apply 2-pass regression with time series data I have. I would like to how to use the coefficient estimates from my first equation as my regressors in my second equation. Many Thanks
Re: 2-pass regression with time series data
Isn't that the same basic idea as Fama and Macbeth? Just save the coefficients into series and use them as data in the second regression.
fan
TomDoan wrote:Isn't that the same basic idea as Fama and Macbeth? Just save the coefficients into series and use them as data in the second regression.
Thank you, Tom. I tried as you suggested here. but my code did not work. Could you please kindly take a look my code?
linreg y
# constant x
compute beta1=%beta(1), beta2=%beta(2)
linreg y
# beta1 beta2
Don't you need to run separate regressions over t for each SB (whatever the latter index set is) and collect the coefficients from those?
fan
TomDoan wrote:Don't you need to run separate regressions over t for each SB (whatever the latter index set is) and collect the coefficients from those?
Thank you for your quick reply. I thought I could have the coefficients for each SB from my first regression.Is it not right?
linreg sb1
    # constant x
    linreg sb1
    # beta1 beta2
No. One LINREG does one regression. You need a whole collection of regressions at the first stage.
