2-pass regression with time series data
fan
I am trying to apply 2-pass regression with time series data I have. I would like to how to use the coefficient estimates from my first equation as my regressors in my second equation. Many Thanks
- model.png (4.37 KiB) Viewed 10517 times
Re: 2-pass regression with time series data
Isn't that the same basic idea as Fama and Macbeth? Just save the coefficients into series and use them as data in the second regression.
fan
Thank you, Tom. I tried as you suggested here. but my code did not work. Could you please kindly take a look my code?TomDoan wrote:Isn't that the same basic idea as Fama and Macbeth? Just save the coefficients into series and use them as data in the second regression.
linreg y
# constant x
compute beta1=%beta(1), beta2=%beta(2)
linreg y
# beta1 beta2
Don't you need to run separate regressions over t for each SB (whatever the latter index set is) and collect the coefficients from those?
fan
Thank you for your quick reply. I thought I could have the coefficients for each SB from my first regression.Is it not right?TomDoan wrote:Don't you need to run separate regressions over t for each SB (whatever the latter index set is) and collect the coefficients from those?
linreg sb1
# constant x
linreg sb1
# beta1 beta2
No. One LINREG does one regression. You need a whole collection of regressions at the first stage.
