I'm trying to estimate a univariate state space model including one exogenous variable in the state and one exogenous variable in the observation equation.
I got problem at the DLM estimation with the error : ## MAT2. Matrices with Dimensions 1 x 5 and 3 x 1 Involved in ~~ Operation
So, please help me to see and fix the problem.
I attached here two files:
+ The first present the Unobservable component models
+ The second show the codes Rats
And please give me some advises to deal with this model.
Many thanks
Univariate state space model + exogenous variables
May-June
- state space 5jan2014.docx
- The Unobservable Component Model
- (12.31 KiB) Downloaded 910 times
- TEST.RPF
- The codes in Rats
- (2.92 KiB) Downloaded 1173 times
Re: Univariate state space model + exogenous variables
The "C" matrix is entered into the model as a transpose, so CS is 3x1. You're combining that with a 1x5 CTC. BTW, CTC is a fixed matrix, so there is no reason for it to be a FRML---the only part of C that is time varying is PETROL. Either use TR(CTC) or redefine CTC as a 5x1 rather than 1x5 matrix.
May-June
Thank you very much. It works.
