Businesss Cycle and Business cycle Synchronisation
danon
Unread post by danon »
Hi Dear Tom,
I am looking to replicate some works on business cycle turning points and business cycle synchronization.
There exist some papers and codes (GAUS and MATLAB) Please see attached papers. The codes are available as well.
1- business cycle turning points
* Extracting nonlinear signals from several economic indicators (Camacho 2014)
CAMACHO-MSDFM_1svs2s.pdf
CAMACHO- GAUSS codes available
(422 KiB) Downloaded 871 times
- Gauss codes available.
*Kim-Nelson (1998): Business cycle turning points, a new cincident index, and tests of duration dependence based on Dynamic Factor model with Regime switching- Gauss codes available.
Kim-Nelson_RES98.pdf
Gauss Codes available
(679.86 KiB) Downloaded 834 times
*Dating Business cycle Turning points for the French Economy: a MS-DFM approach (Petronevich 2015)
Petronevich -Matlab.compressed.pdf
Matlab codes available
(978.9 KiB) Downloaded 825 times
- Matlab codes avalibale
2-business cycle synchronization
* Camacho : A new framework to analyse business cycle synchronization
Camacho-BS Synchro.pdf
(354.55 KiB) Downloaded 838 times
Is there any way to work this out in RATS ? I would be happy to pay for a special course for a step-by-step explanation of the RATS functions.
Best regards
Danon
Re: Businesss Cycle and Business cycle Synchronisation
Pretty much the whole point of the Kim and Nelson book is to develop the MS-DFM model from their 1998 paper. kimnp126.rpf estimates the model using the "Kim filter" and kimnp247.rpf does it using Gibbs sampling. I'm assuming the other papers are relatively similar.
