Graph editting
tyzellar
Graph editting
Unread post by tyzellar »
Dear Tom, Could you please tell me how could I edit the impulse response functions graphs, in order to be able to clearly distinguish between the two IRF functions and the standard errors. Attached to his post you will also find the code and the dataset.
spgraph(vfields=1,hfields=5)
do j=1,1
dofor i=1 2 4 5
compute factor76 = acresp76(j,j)(1)
set respons76 = acresp76(i,j)/factor76
set stde = sqrt(seconda(t,i+(j-1)*nvars))/factor76
set upp = respons76 + band * stde
set low = respons76 - band * stde
graph(header=implabel(i),hlabel="horizon",number=1) 3
# upp 1 nsteps 2
# low 1 nsteps 2
# respons76 1 nsteps 1
print / respons76 upp low
compute j=1
set respons76 = resp76(3,j)/factor76
set stde = sqrt(second(t,3+(j-1)*nvars))/factor76
graph(header=implabel(3),hlabel="horizon",number=1) 3
# upp 1 nsteps 2
# low 1 nsteps 2
Re: Graph editting
What was it that you wanted to change. The black line with blue upper and lower is pretty standard.
tyzellar
Re: Graph editting
In the last part of the code, I insert in one graph two impulse response functions and I get this graph, which is not so clear. I run this code and I receive the following graph. I would like to have two different colors for the IRFs and one color for the confidence bands. Thank you in advance!
do j=1,1
dofor i=1 2 4 5
compute factor85 = acresp85(j,j)(1)
do n=1,nsteps
compute respons85(n) = acresp85(i,j)(n)/factor85
compute respons76(n) = acresp76(i,j)(n)/factor76
compute stde(n) = sqrt(seconda(n,i+(j-1)*nvars))/factor85
end do n
set upp = respons85 + band * stde
set low = respons85 - band * stde
graph(header=implabel(i),hlabel="horizon",number=1) 4
# upp 1 nsteps 1
# low 1 nsteps 1
# respons85 1 nsteps 1
# respons76 1 nsteps 2
compute j=1
set respons85 = resp85(3,j)/factor85
graph(header=implabel(3),hlabel="horizon",number=1) 4
# upp 1 nsteps 1
# low 1 nsteps 1
Re: Graph editting
You are using 1 (i.e. black) for upp, low and respons85, while 2 (i.e. blue) for respons76. I would think that using respons85 and respons76 should be something different from each other and from upp and low.
# upp 1 nsteps 1
# low 1 nsteps 1
tyzellar
Re: Graph editting
You are totally right. Thank you very much. I really appreciate your help!
