BB algo and Hamilton MS-AR Outputs
danon
Is there any possibility to:
1- get the outputs for the BB algorithm in graph as well ? we only get numbers .
2- get Hamilton's MS-AR graph in color rather than in Back and white only?
Please have a look on images attached
Best regards
D
Best regards
D
- Hmilton's results - Any colored Graph version
- Screen Shot 2017-04-10 at 11.50.00.png (111.53 KiB) Viewed 25608 times
- BB Results - Any colored Graph version ?
- Screen Shot 2017-04-10 at 11.46.54.png (61.89 KiB) Viewed 25608 times
Re: BB algo and Hamilton MS-AR Outputs
You can use the PEAK and TROUGH options to get dummy variables with the turning points. I'm not sure there's any obvious "graph" directly out of the procedure, but you can use those dummies in other graphs.danon wrote:Dear Tom,
Color what? You can change the color on the data by overriding the default style number (1 = black).danon wrote: 2- get Hamilton's MS-AR graph in color rather than in Back and white only?
danon
Thanks again Dear Tom
I did change the quaterly to monthly in your hamilton's program.
I got the IP growth graph only.
Unfortunately I got an error message because of recession's dummy
variable to be create. but I do not know how?
The changes:
cal(m) 1999:1
open data ipci.prn
data(format=prn,org=columns) 1999:1 2016:12
set g = 100*log(IP/IP{1})
graph(header="IP growth")
# g
* Set up a mean-switching model with just the one variable and four lags.
@msvarsetup(lags=2,switch=m)
# g
compute gstart=1999:1,gend=2016:12
frml msvarf = log(%MSVARProb(t))
Error is:
## SX11. Identifier RECESSQ is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>ontract = recessq==<<<<
Common errors are
* a missing $ at the end of a long line which continues to the next
The data file used contains only the IP series ( no dates series, no recession series because I do not know how to create
the recession series)
Please can you help !?
The changes:
cal(m) 1999:1
open data ipci.prn
# g
# g
Error is:
Common errors are
- ipci.prn
- IP series file
- (2.32 KiB) Downloaded 1103 times
You can use the @NBERCYCLES procedure to generate the recession dummy that was hard-coded into Hamilton's data set.
danon
Dear Mr Tom,
Thanks for your help so far. I am nearly done !
Indeed I have two questions.
One on the result of the BB algorithm on the growth rate of monthly industrial production series and
One on the results of Hamilton 1989 on the the growth rate of Quarterly industrial production series.
For the BB algo on monthly growth rates i have this:
open data ipm.xls
cal(m) 1999
data(format=xls,org=columns) 1999:1 2916:12 ip
set ipg = 100*log(ip/ip{1})
log ipg
@BryBoschan(print=final) ipg 1999:2 2016:12
## MAT13. Store into out-of-range LPEAK(0)
## I2. Expected Instruction Here
>>>>#<<<<The Error Occurred At Location 133, Line 14 of BBENFORCEENDPOIN
/Applications/RATS 9.1/Procedures/bryboschan.src Line 230
Called From Location 2807, Line 155 of BRYBOSCHAN
/Applications/RATS 9.1/Procedures/bryboschan.src Line 505
On the Hamilton 1989 (quaterly growth rate) i have this:
MAXIMIZE - Estimation by BFGS
NO CONVERGENCE IN 31 ITERATIONS
LAST CRITERION WAS 0.0000000
....with non significant probabilities.....
NB: FULL CODES ATTACHED (BB & HAMILTON) + GRAPHS OBTAINED ( for HAMILTON)
Thnaks
open data ipm.xls
cal(m) 1999
log ipg
Thnaks
- Full Codes_BB_and_Hamilton.rpf
- Codes and the error message.
- (3.73 KiB) Downloaded 1066 times
- Quarterly growth rates.rgf
- Used on hamilton
- (760 Bytes) Downloaded 1079 times
- Probabilities.rgf
- Hamilton probabilities
- (1.63 KiB) Downloaded 1091 times
Your DATA instruction has a typo: I don't think you actually mean 2916:12
Also, BB applies to the log of the series, not the growth rates.
The Hamilton model doesn't converge when applied to US GDP growth over a longer data span. The fact that there was only one (fairly minor) recession between 1982 and 2001 with fairly regular cycles before that causes the model to break down. So it's not shocking that you might have problems.
danon
Thanks a lot
yes it was a typo as it is 2016.
I wanted to remind you that I m using my own data (Idustrial production monthly series from a country in africa from 1999 to 2016) and not US GDP.
Should I consider that it makes sense that the hamilton algoritm gives such results as if it was US GDP !?
Please have a look on the data i used...
Best
Thanks a lot
Best
I seriously doubt that you can get the Hamilton model to fit that. You have 20 and 30% quarter to quarter changes with almost immediate reversals rather than actual cycles. Do you know why the data are so variable? It looks almost like timing errors where some (substantial part) of production gets applied to the wrong quarter.
danon
I did convert monthly data to quarterly series because the codes was not working on monthly data.
With qarterly data i could get those amazingly non reasonable estimates.
attached is the original data ...
may be you can help !?
Best
Best
Needless to say, that's even worse. (The quarterly averages smooth out some of that, but not much)
danon
Do you mean that using monthly data is worse !?
Camacho (2006, attached) used monthly IP with Hamilton 1989 as well but using GAUSS.
Please, having looked at my data, what would you suggest ?
Danon
Danon
Please read what I wrote above: https://estima.com/forum/viewtopic.php?p=14156#p14156. Compare the overall appearance of their monthly data (Figure 1) with yours. It has nothing to do with the software, or data being monthly or quarterly and everything to do with your data being far too noisy.
The point above about the problem with the Hamilton model and US GDP is cautionary. Hamilton's model fit spectacularly well to the data set to which it was applied. The results were reproducible, the transition probabilities made sense and it hit almost spot-on the NBER cycles. Same model, same data series, but extended for another 10 years---doesn't work. It tries to turn the 1981-2 recession into a one-off outlier.
danon
If I do understand well, I should detrend as much as possible in first place until i get smoothed series.
Am I correct ?
Am I correct ?
Detrending has nothing to do with it. It's the period-to-period whipsawing that's the problem.
danon
This is too technical dear Tom.
Is there a process to follow for this ?
Best
Best
